I have checked the outlets they work but machine does nothing no led lights nothing,it acts loke it is not getting power. i think it may be control board was told there are two on this paticular model, not sure which one i need? or if it could be something else?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
when i plug it in it doesnt even turn on.it is a touch screen and i get no lights i cant get it to power up.this is why i believe it to be control board.
Did you check the lid switch?
Have you checked the lid switch and Out of balance lever/switch?? this will seem like the same problem but will be alot cheaper.
