Any resolution other than 480i on any input and the screen is scrambled. Osd displays fine.
SOURCE: Horazontal line across the bottom of the screen
Have you seen a same problem when playing DVD? If yes, the main board got defected
SOURCE: Sony PFM-42V1N 42 in. EDTV-Ready Plasma
Yea the TV supports Pal 60 I had to use the bnc connection to AV. but yeah the tv supports Pal 60 you need to go into the menu and select it just the colours arnt very good on this TV
SOURCE: how to change a sony bravia resolution from 480i
U can't not,only resolution can get,it the show u watching give u the resolutions.Want more HD 1080i must order a HD package from the cable,satalite or telicom companies.
SOURCE: PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
SOURCE: resolution
If you're talking about off-the-air (outside antenna) reception, the set should take care of the switching automatically. If you receive the video from a set top box, DVD player/recorder, SAT receiver or CATV receiver, you may have to set the output resolution of the device. Bear in mind, composite video (yellow jack) is 480i only, S-video is rated 480i or 480p, component video (RGB) can do all resolutions and HDMI can't do 480i but does all the other resolutions. If you are plugging your external device into either composite or S-video, you will only get 480 max.
