SOURCE: mitac mio 168 digiwalker
Hi, to replace battery, you need to undo the 4 screws hold the back casing. When these are removed you can open the back, revealing the battery. There is a black plug that pushes into a white socket on the pcb, with 4 wires coming out of it that goes to the battery. Pull this plug out and the battery then comes free. Hope this helps.
SOURCE: Mitac Mio 168 Digiwalker cannot recon SD card
your SD might be and SDHC or larger that 4GB. try to use a FAT32 formatted SD, no bigger than 4GB
Testimonial: "what if its bigger than 4GB?(i used an 8GB card actually)...i'll try and let you know...thanks"
SOURCE: I have a Mio P550 Digi walker. How do you open the
I removed the rubber infill that covered a hidden screw. Released screw and then removed back plate. Removing the battery then required care as it is stuck with two sided tape to the Mio internals. Here I used a knive to prise/cut free.
