Cameras Logo
nima yade Posted on Jun 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung SL201 Samsung SL201, i want to turn it on but the lens doesn't move and make a sound as it appear in the video, after that it will turn off
CameraR
Level 3:
  • Cameras Master 4,738 Answers
  • Posted on Jun 23, 2013
CameraR
Cameras Master
Level 3:
Answers
4738
Questions
Helped
1195969
Points
12483
Here are some troubleshooting steps that you can try that may correct your problem. If the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
And the above is a video summary of some (not all) of the steps:
3 Related Answers
bharat patel
  • 268 Answers
  • Posted on Jul 28, 2010
SOURCE: Samsung sl201 lens will not
Lens extender is slipping / not turning within the camera. Take it to the repair shop.
Anonymous
  • 455 Answers
  • Posted on Jun 26, 2011
SOURCE: Hi. I have a Lumix
I'm sorry to know that the Camera Lens is not focusing and retracting. I'll be glad to assist you with this. I suggest that you perform a power reset of the Camera and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If you're able to access the Menu of the Camera, then reset it back to factory reset and check if it helps. Press the MENU button, press the Right Arrow button and select the SETUP Menu of the Camera. Now press the down arrow button to select RESET. Resetting the Camera will change all the settings to factory default.
Performing the steps should resolve the issue.
Thanks for using FixYa.
  • 102366 Answers
  • Posted on Oct 22, 2012
SOURCE: Lens doesn't move cannot take pictures
Try these procedures.
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
How do you set the aperture lock on the Nikon 50mm AF F1.8 non D lens?
On my lens I just turn the ring to its smallest setting. I can't seem to move the orange slider very well, and it doesn't seem to matter. I think it's just there to prevent the ring from moving accidentally, and the camera only cares about the ring position.
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Hi . I have an old original X Box console It turns on and it sounds like it is going to work then it says that it doesn't recognize the disk.
Check for the disc to be clean, and if possible use a lens cleaner on the unit. If this doesn't work, the DVD laser must be damaged. In that case, you must replace it.
When connecting my Samsung SL201 Camera to my computer ,(which I've done several times before with success), is now telling me their is a USB Error . Can you please tell me what to do??
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Our Samsung SL201 camera shuts down as soon as we turn it on. We purchased a new battery and it continues to do the same thing.
If it beeps before it shuts down, this indicates the lens cannot extend properly. Often dirt or sand is the problem and it will need to be professionally serviced.
1helpful
Samsung sl201 lens will not extend, then camera shuts
1helpful
2answers
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
