I have purchased a used Sharp AR-287. The key operator code is unknown. I need to reset the key operator code in order to use the machine.
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
This was the solution. Thank you so much for your assistance!
