Has the brake cable come outy of position and is stopping it opening fully? This happened to mine and was easily fixed!
My Hydraulics are fine, but the problem is the metal piece that the hydraulic rod presses against to provide resistance is broken. Does anyone know where to get it repaired ? I bought the european one and is out of warranty as well. Can you send the chassis to dorel in usa and pay for a repair ?
I had the exact same problem with my quinny buzz. When i went to get it repaired i was told that we had broken the gas line in the hydrolics in the frame. When i tried to collapse the buzz for the first time, when i got the the point where you meet some resistance (if you haven't pressed and pushed the buttons properly) i forced it closed which broke the hydrolics. This can't actually be repaired but the pram can still be used safely as long as you manually snap the frame up, ensuring it locks into place. The two black parts meet at the top when it's locked in properly so you should be able to see if it is or not. Make sure when you collapse the pram that you do press and push the buttons fully. You should meet no resistance and it should collapse freely when this is done properly. Hope this helps!
SOURCE: quinny buzz
This sounds like a faulty quinny. If it is collapsing while you are pushing it, you should immediately contact quinny: find out the contact information on quinny.com . It is country specific, so you will have to choose yours and go from there. Let them know that it is collapsing on its own and they should send you a new chassis.
Hope this helps,
StrollerInfo
www.StrollerInfo.com
SOURCE: quinny buzz
Hi if you have not got bags on the handle then yes it needs replacing if it is less than 2 yrs old you can call dorel to fix it, also I have heard that if you send the frame to them & £30. for a service the will fix it. Let me know if this works.
