Question about Midland LXT380 Two Way Radio
Repair NO SOUND OR BEEP EVEN WHEN YOU SWITCH ON TH RX SYMBOL COMES ON
  • BRIAN HUE Jun 26, 2013
    does not have sound when other radio calling you
  • Midland Master
  • 1,655 Answers
Here is a link to the MC series user guide: http://www.giantintl.com/ContentManage-new/manuals/Moto/MC%20UG%20KEM-ML36100.pdf
Best regards
Posted on Jun 25, 2013
6ya staff
SOURCE:
Replaced lamp now lamp light keeps flashing still also the stand by temp light flashes
Sounds like a door switch is not making proper contact--or has been damaged. Check the lamp door switch and see if it is properly seated and the pin on the door is hitting the leaf of the switch.
Mar 06, 2014 | Samsung HL Televison & Video
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
Doesn't beep
If it is not the sound settings then it is most likely a faulty speaker.
Contact www.portablesolutions.com for a repair.
Aug 12, 2013 | Symbol PPT 8800 Portable Terminal
I need to turn off the beep on the Symbol MC9090 when I use the barcode scanner
What I have done is I taped the speaker opening on the back of the scanner with two stickers to reduce the beep volume to almost zero. So 3 to 4 stickers would probably eliminate the beep completely.
May 20, 2010 | Symbol MC9090 Barcode Scanner
Problem with surround sound on JVC Th-C5 sound system
Not sure how you're hooked up or what model TV you're using. If you mean the TV sound through RCA cables is the source and you're wondering why it's not surround. Well, it's not multichannel. Please fill in some details.
Dec 25, 2009 | JVC TH-C5 System
When th comes it makes a loud beep and then
yiou have a hardware issue time to take it or send it to someone or buy a new laptop
Oct 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Sound skips
If you are using HDMI, switch to either "Digital Coaxial" or "Optical". Do you have DSS, Cable, or FIOS? Post a comment and I can help some more.
Aug 05, 2009 | Yamaha RX-V663 Receiver
1.When I try to type @ symbol by pressing th **** and 2 keys, the symbol " comes up. @ comes up when **** and ' keys are pressed 2. Hash symbol does not come up when **** and 3 are punched, instead £...
It sounds like you have another keyboard layout set as your default.
In Control Panel, double click "Regional and Language Options". Click the Languages Tab and then the Details button. Make sure that English-US is selected as the Default Input Language.
If another keyboard layout is listed below and you don't need it there, you can remove it to make sure it doesn't switch itself again.
Note: this is for XP. Vista will be similar, but I don't have a vista machine so I can't tell you exactly what the options will be called.
I hope this helps. Good Luck.
Jun 10, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
OIL SENSOR LIGHT ON 2001 Audi 2.8liter
It could simply be maybe the person changing your oil never reset the light? or you have a oil pressure sensor leaking or not working.
most of the time its someone never reset the oil change light. even before it goes on it goes by mileage, so maybe it didnt go off yet cause you cnahged it a tad early.so noone even tried to reset it.
I guess you could have an oil pressure problem, but thats going the extreme route.. but if nothing else shows that could be a problem.
Apr 29, 2009 | 2001 Audi A4
Midland LXT380 Two Way Radio Logo
137 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Gene Pitts
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
