SOURCE: Unlock Alcatel OT-C701
hi sir..
it may be useful link
www.metacafe.com/watch/711995/how_to_unlock_almost_any_cell_phone_for_free/
thank sir
just rate it
SOURCE: when i on my alcatel ot c 701 it asks for product password
this is not a preset code.
you would have set this yourself, try every password/pin/lock you would have used on the phone, there is an unlimited amount of tries.
i had the same problem and spent hours searching the internet as to how to solve it, then tried one of my old codes and it worked.
SOURCE: how do I enter the NCK unlock code for my Alcatel
Do you have the unlock code? If you have the unlock code you simply switch on the phone with an alternative network sim card (a network other than the network from which the phone originated) and the phone will prompt you to enter the code. Quite a few OT800's require the NCK and SPCK code. If you only have one code or if you don't have a code at all, try the link below.
Unlocks
SOURCE: i need a puk code
Hi, Puk it's does not anything to do with the cell phone you are using,But the Sim card.
Puk comes up when you type in the wrong pin code three times and it pops up 'Enter Puk code'
Puk codes tounlock your cell phone can be given to you by your service network provider of the sim card your making use of..
You can contact them by going to their nearest outlet around your area for help ..
Also you can contact them through the Phone, by using a friends phone to call them for help..
Good thing about it ,is that CALL IS FREE..
Call your service network provider for help to day and unlock your phone in few seconds.
Hope it helped..
Thanks and good luck.
SOURCE: necesito una forma facil para liberar mi cel
hola
puedes probar los c?digos
para desbloquear el
m?vil
usted puede
obtener
los c?digos
de aqu?
http://www.onlinegsmunlock.com/alcatel-ot-c701/rs7wp9/
