Dell Inspiron Mini 1012 Netbook (IM1012799OBK) Logo
Daryl Hall Posted on Jun 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My netbook show Operating System not found. - Dell Inspiron Mini 1012 Netbook (IM1012799OBK)
Walter H Boehm
Level 3:
  • Dell Master 998 Answers
  • Posted on Jun 25, 2013
Walter H Boehm
Dell Master
Level 3:
Answers
998
Questions
0
Helped
340684
Points
2289
Either your software is corrupted, have a defective hard drive, or the hard drive controller is defective.
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Sep 05, 2010
SOURCE: My netbook says "Operating System
What were you doing prior to this error message ?
Did you try to install another OS or During installation did you abort the process
A clean installation of windows will resolve the issue
Or Try this
If you were able to start the computer prior to the issue, then try startup repair and check the result. To do this, try these steps.
Step 1: Perform startup repair using Vista DVD
a. Insert the Windows DVD.
b. Restart your computer.
c. Let the computer restart (boot) from the DVD.
d. If prompted, press any key to continue.
e. When you reach the Install Windows screen, select your preferences in the Language to install, Time and currency format, and Keyboard or input method boxes, and then click Next.
f. Do not click Install now. Instead, click Repair your computer. The System Recovery Options dialog box appears.
g. Make sure the correct operating system is selected, and then click Next.
h. After you click Next, the System Recovery Options menu appears.
i. Click Startup repair. Once the startup repair completes, click Finish to restart the computer.
j. Remove the DVD and restart the computer to see if the system starts fine. See Make system repairs from the Windows Recovery Environment
Also see http://support.microsoft.com/kb/932932 Go to BIOS (basic input/outputsystem (BIOS) and make hard disk as first bootable device. See BIOS: frequently asked questions
http://windows.microsoft.com/en-US/windows7/BIOS-frequently-asked-questions Important: Modifying BIOS incorrectly will cause serious damage.
Hope this helps
Operating system not found?
Please what O.S. working on the computer?if have XP I find something about it. The Operating System Not Found Message Appears When You Start The...
My notepad says operation not found
Does it say "operation not found", or "operating system not found"? Big difference...
Samsung netbook says"no operating system found"
Hello there,
you have couple of options. You can restore your system to some date it was working. Or simply reinstall your operating system from the CD or DVD.
Hope this helps
2helpful
3answers
My aspire one netbook says missing operating system what do i do
On my Dell Insprion Windows 7, I have got "Missing Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
2answers
Advent netbook windows not loading on switch on
You will need to do a repair install of the windows operating system. This can be problematic on netbooks with no CD drive unless you have access to an external USB CD drive and a copy of the operating system.
Please rate this solution if it has helped you.
Thanks, Gary
Cant connect my laptop to my 2wiregateway When I turn on mini computer it says operating system not found
Hi. You may need to re-install the Operating System but your netbook doesn't have an Optical drive. Better call Dell Phone Support for help in how to recover system back to factory image.
^_^
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
