Question about Dynex 32 in. LCD Flat-Panel HDTV
I need the dynex tv code for a comcast remote control
I cannot program my universal comcast remote to my dynex flat panel, please help!!!!!
  • rmartin570 Apr 16, 2009
    code for comcast universal remote is needed. If you know a code that will work please let me know. coolcatcatering@hotmail.com
  • Shannon Jun 02, 2013
    10463 for the Dynex flat screen 32 inch worked on the first try..
  • 3 Answers
Try 10463, or the Emerson tv code.
Posted on Apr 09, 2009
    New Friend:
10463 worked great for our 26" dynex... thanks!
Posted on Aug 26, 2010
  • 1 more comment
  • cmpaulsen771 Dec 04, 2010
    10463 worked for me too !!
  • nrb119 Dec 10, 2010
    Thank you. This code also worked well with my Dynex™ 32" Class / 720p / 60Hz / LCD HDTV.
  • monitolocome Dec 27, 2010
    thank you man that's why i use the Internet for people that have money
    New Friend:
10463 still works; 32" Dynex bought last week December 2010
Posted on Jan 04, 2011
  • charetterls Jan 31, 2011
    That works, but the input button does not.
    totally worked on the first try....Thank u!
The Emerson code 10463 worked great. Thank you! Stan
Posted on Jul 29, 2009
    New Friend:
10463 worked on my 46inch dynex as well. thanks!
Posted on Dec 17, 2010
  • 431 Answers
Sassy difficult question without seeing the equipment and it's
set up you may find that what you have is caused by an earth leakage problem sometimes equipment that runs on two cable mains ie no ground hasn't got the best of decoupling capacitors installed ie they are cheap . This gives way to bleed over from the ac manis causing a very low signal that dissrupts pictures .. this can show in Hum Bars .. Vertical bars that run down the screen
Horizontal tare . Pictures tend to jump a little sideways (flicker )
and a buzz on sound this is the most common result as most IF panels are well filtered from this interference ( or should be ) and of course picture striations or flare .usually most noticeable on RED .
Unfortunatly this is a sod to fix the only real way is to replace all the decoupling caps in the offending equipent . but another is to fit a capacitance attentuator this stops the flow of the intrerference usually ... One other reason may be you have the colour turned up far too high ?. go into settings and choose default settings and see if this cures it ,hope this helps.. Regards Vortash
Posted on May 02, 2009
  • Anonymous May 15, 2009
    Sorry dont know what happened here lol the other people must have got your remote control codes ? have a nice day Vortash ..
    New Friend:
  • 3 Answers
I do not know how to use the URC 3220 for the Dynex 32 Flat LCD TV what code do I use
Posted on Jun 19, 2013
    Problem Solver:
  • 6 Answers
10463 didn't work for me. It turns the TV off but the Dynex keeps turning itself back on a 1/2 second later.
Posted on Jun 18, 2012
Anonymous
SOURCE:
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
What code do I use to set up a universal remote
Code 10463 is Dynex code in UEI made remotes, like comcast, Directv white remotes and so on.
Jul 09, 2011 | Dynex Televison & Video
Can I operate my DX-DVD2 with my Comcast remote, and if so, what is the devide code for programming same?
I doubt that Comcast remote will work in your Dynex DVD player. You may view the pdf format manual of this remote at this LINK. Click the model no. of your remote control and then click the "download manual" at the top right. Listed there the brand's compatible for that model. Note that the universal remote control has a limitation and only compatible brand listed in the manual can access the unit. Most of the universal remote control has a limited brand compatible most especially in DVD's.
You may also click this LINK to buy an original remote control of your DVD player online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 27, 2011 | Dynex Televison & Video
Need tv code for comcast remote
Hello
Codes for Dyenx TV with Comcast universal remote control are
11463/11780/11785
Mar 20, 2011 | Dynex Televison & Video
Remote control code
Check REMOTE codes here
<a heref="http://universalremotecodes.blogspot.com/">Magnavox Universal Remote</a>
Jul 05, 2010 | Dynex DX-LCD37 TV
How do i set up my dynex rc-401-0a remote to operate my sanyo dvd player
how do i program my dynex remote for my comcast box and sony blue ray
Feb 07, 2010 | Dynex DX-LCD32-09 LCD TV
Remote code for comcast
Dynex has a website with the codes. It worked for me the first try.
I have the 42" LCD HD code 0463 for Comcast also 10463 if your remote takes 5 digits.
Nov 28, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
Jun 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
TV CODES
the code is 10463 brian
Jun 04, 2008 | Televison & Video
Dynex 32 in. LCD Flat-Panel HDTV Logo
28,574 people viewed this question
Top Dynex Televison & Video Experts
Vitally Alcher
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
