MY DRYER RUNS BUT ONLY PUTTING OUT COLD AIR. WHAT CAN I DO TO FIX? WHERE CAN I FIND A PICTURE DIAGRAM OF THE BACK OF MY DRYER?
Need to know brand name and model#..........but it sounds like your only getting 110volts to the dryer instead of 220volts........The moter and controls will run on 110v. but the heaters require 220v. carfully remove small cover on back or if you have a outlet(wall plug) you must check for 220volt...PROBABLE CAUSE 1 fuse blown,,,, or bad circiut breaker. FIRST is there 220v. at plug This will tell us if it's a wiring prob. or dryer prob.
machine is not but no heat coming out. what can it be??
