Question about Lisle Serpentine Belt Tool & Accessories - Expanded Model
Diagram serpentine belt for a ford f-250 7.3l diesel
The sticker was removed at a repair shop
I had this same thing happen to me. i spent some time trying to find a image of this so i could replace my belt. ford dealers will help. but for me this was not a option. so i searched the net. here is a image that may help.
Posted on Jun 26, 2009
    New Friend:
That is the proper diagram, however do NOT get a Gates replacement belt, they will slip and squeal within hours of installation.
Ford or Dayco #278 are the only ones that will fit. The tensioner can only take up about 1" of slack and the Gates belt is slightly longer. Once it heats up and streches it slips and melts the ribs which causes more slipping. Now the belt is ruined, cant be returned and your truck still needs a belt
Posted on Dec 29, 2009
6ya staff
SOURCE:
I need a diagram of how to replace serpentine belt on 2011 ford f350 6.7 diesel
I would check underside of hood or radiator core support, they usually have a sticker with a diagram of how to do that, unless somebody peeled it off.
Feb 19, 2015 | Ford Cars & Trucks
Serpentine belt diagram
IF IT IS NO LONGER ON RADIATOR CORE SUPPORT (ROUTING DIAGRAM STICKER) CONSULT A SHOP MANUAL. JUST GO TO AUTOZONE, UNWRAP ONE (KEEP IT CLEAN) AND MAKE DRAWING OF ROUTING
Dec 16, 2013 | 2004 Mustang Factory Wiring Diagrams
Need fan belt diagram
There should be a sticker under the hood near the front with a serpentine belt diagram. If the sticker is missing then you can also find it in the owner's manual. If no owner's manual you can purchase a Haynes or Chilton's manual which will also have the diagram plus many useful tips and repair instructions you may need down the road.
Apr 01, 2011 | 2000 Ford Taurus
I need a serpentine belt routing diagram for my 2004 Ford F250 6.0 diesel. Where can I get one?
my 2002 f-350 had a sticker under the hood with the belt diagram,yours might have one under there?
Sep 24, 2010 | 2004 Ford F250
The serpentine belt replacement
Use the (B) 1/2 inch square hole in the drive belt tensioner pulley hub to rotate the (A) drive belt tensioner clockwise and remove the (C) drive belt.106fae5.gif
The diagram should be on a sticker somwhere under the hood, on the side fender area, or near the front of the truck. Or before you remove the belt draw a sketch to remember the routing of the belt.
Mar 24, 2010 | 2004 Ford F350
I need a diagram for replacing my serpentine belt on my 1998 ford escort ZX2
it should be under the hood on asticker somewhere in the front around the radiator.if the sticker has been removed register the vehicle at autozone.com and look under the vehicle repair guide
Dec 29, 2009 | 1998 Ford Escort
Replace a serpentine belt correctly
if no sticker under the hood to show the route. go to the auto parts store and ask for a belt diagram. if the don't help, try your local repair shop. best of luck.
Aug 06, 2009 | 1994 Jeep Grand Cherokee
Diagram for serpentine belt for 1992 ford f250 7.3 diesel
First off---Have you looked under the Hood for the Factory Belt Routing Sticker? If not there look in the Owners Manual. If not there let me know so that I can Locate you one.
Jan 20, 2009 | 1992 Ford F250
Drive belt diagram
Hi, Have you tried your local library? They are usually a great resource for auto repair manuals that would likely cover the 99 taurus serpentine belt diagram.I hope it did not break on you.
Tom
Jul 06, 2008 | 1999 Ford Taurus
Lisle Serpentine Belt Tool & Accessories - Expanded Model Logo
10,835 people viewed this question
Top Lisle Hammering Experts
Robert Wooley
Robert Wooley
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
