You can reset all settings, other than the display language and the print head position, to the
initial state.
Turn on the printer.
Select Tool Box
Tool Box from the Menu
Tool Box
(1) Press the Menu
Select Reset
Reset.
Reset
Reset
Menu.
Menu
Menu
Menu
Menu button.
Menu
(2) Use the
buttons to select Tool Box
press the OK
OK button.
OK
OK
The Tool Box screen is displayed.
(1) Use the
buttons to select Reset
press the OK
OK button.
OK
OK
The Reset screen is displayed.
(2) Use the
buttons to select Yes
press the OK
OK button.
OK
OK
Tool Box and then
Tool Box
Tool Box
Reset and then
Reset
Reset
Yes and then
if you want to get proper detailed information about canon printer support service then you should call on 1-888-924-2961 toll free number anytime.
Technical Support For Canon Printer
1. Hold down the "Resume" button on your Canon printer for one to two minutes, and then release the button. In some instances, this may reset the printer automatically.
2. Unplug the power cable from the back of the Canon printer if the printer did not reset when you held down the "Resume" button. Hold the power button down and plug the power cable back into the Canon printer. Do not release the power button.
3. Press the "Resume" button on the Canon printer two times and release the Canon's power button. The Canon printer resets to the factory settings and the ink level should appear full.
If you will need more help you can download the service manual for canon ip6000d from the below link:
http://goo.gl/gAqyP
Thank you
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
