Question about LG WM-2277HW Front Load Washer
WW2277HW Washer shows an "OE" on the message light. It will not go into the spin cycle. I have removed the filter and cleaned it but it wasn't clogged or dirty. Reinstalled the filter, checked the drain hose to see that it wasn't kicked and tried it again and still no spin cycle. What next? John
  • LG Master
  • 2,528 Answers
My guess is replace the drain pump. Inexpensive part but kinda hard to get to. Check out repair videos on parts sites or YouTube
Posted on Jan 31, 2018
6ya staff
SOURCE:
sheila skaggs
  • 383 Answers
SOURCE: OE problem with the LG WD - 12270BD Washer
Turn the knob to start and restart again let it run thru the course.
AND IF THIS DONT WORK TRY THIS:
Put knob on spin and let it run thru the course.
Posted on Nov 26, 2007
Mukesh Kumar
  • 3230 Answers
SOURCE: water wont drain
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Good Luck!!
Posted on May 06, 2009
Anonymous
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: wm2688h will not drain anymore.
You need to take a flashlight and look into the suction port on the pump. Make sure the pump is not clogged and check the pump impeller. Make sure that no blades are broken or missing and the impeller should spin freely. If any blades are missing or broken on the impeller or if it will not turn freely, the pump will have to be replaced. Hopefully, it is just a clogged pump. Hope this helps and best wishes.
Posted on Aug 09, 2009
jan mczeal
Jan McZeal
  • 632 Answers
SOURCE: oe message on lg front loader washer model
It is a long drain error and occurs when the washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Drain Pump Connector The connector may be disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
Posted on Nov 24, 2009
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
During a wash cycle, the washer will not spin, and displays the message OE after a few minutes of the motor running, but no spinning.
OE drain error. Water not drained after 10 minutes. Look for junk in the filter or pump.
more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 29, 2010 | LG WM2455 Front Load Washer
My washer machine keeps displaying OE. We have checked all the hoses, and everything seems fine. Will not empty water or finish cycle
Error Message : the OE is (outlet error).
1) If OE error occurs, clean & empty the filter.
2) If this doesn't solve the problem, and it won't drain, then provided that you can hear the pump spinning (the normal whirring the machine makes that should be accompanied by the water going down the drain) then the hose pipe leading to the pump is probably blocked.
I'm sure a lot of dodgy service people might just charge you for a new pump & labor, but if you can hear the pump spinning then you just need to remove the blockage.
Aug 12, 2010 | LG WM-1832C Front Load Washer
Wont spin
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 25, 2010 | LG WM-2277HW Front Load Washer
The washer does not go into the spin cycle
if it gives you an oe code then your filter is blocked or bad water pump clean out filter at front of washer (bottom left corner)
May 06, 2010 | LG WM-2277HW Front Load Washer
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Oe error message and how to open filter on front unit?
What is filters & open it are my problemsDue to that I cann't see some pages
SB
Apr 09, 2009 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
130 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
