I removed a tape from the camcorder about an hour ago and now when I try to insert a tape, the slot won't close properly. When I turn the camcorder on with the tape in it, it makes a loud noise and the camera light flashes red. I don't own this camera so I'd really appreciate any help! Thanks!
SOURCE: Panasonic PV-DV53D
I was having the same problem. here's the solution that worked for me - should do it for you as long as your camera stays on long enough. 1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in. 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on you should be able to view tapes and record. hope that helps!
SOURCE: Red light flashes
First go to this link; http://www.panasonic.co.uk/customer-Support/download-centre.asp Type in NV-MX7 in the search box And select the correct version of the NV-MX7 that you have you will be able to download a user manual which will hopefully tell you how to deal with the problem. If you have no luck finding a solution in there then please post back with the model version and I can hopefully help (all the versions have some different fault indication lights) and differences in the tape loading system. Hope this helps - please post back with model details :)
SOURCE: Black bands and skipping in playback
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
SOURCE: Panasonic Palmcorder PV-43 turns off with a tape inside
you definetly have a tape mech fault and this is going to have to go for repairs to panasonic.
I have the same palmcorder, model DV53D and have had the blinking red light problem 2 different times. The first time I was able to use the menu reset solution listed on this page and it worked. The second time it happened I had been recording with the palmcorder when the battery died. I took the battery off, recharged it, and put it back on but the timing of something was off and the blinking red light was back. I tried to reset a hundred different ways but nothing worked. I finally got some help from another online source that advised me to plug the unit into the ac adapter to make sure I was getting enough juice and to then try reseting from the menu and then putting in a brand new tape in camera mode. It worked.
Ultimately the blinking red light does have something to do with a tape being too tightly wound and I think the combo of using a new tape and the ac adapter got it working again. I was able to put the other tape back in and it's up and running again.
