Remove lower rear panel of washer. Lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
Locate, and remove large black hose on bottom of tub. Remove plastic filter inside, and clean. Check pump also. Refit filter and hose.
Plz rate if helped.
