To enable the ON command sustain, there is a voltage level should be maintained at the function which is driven from the power supply via passive component such as a resistor. Check for an open circuit or incorrect reading value of resisitor.
Your Router Should Be Configured for your Internet Service Provider. To do that you have to contact your Belkin technical support & they will give you a hand. Or Please update some Details about your Internet connection who is your Internet Service Provider. What type of Internet Connection are you using is it DSL or Cable. And i will walk through the Steps For you... :)
without looking at laptops myself, if it's not a problem where somehow a connection got loose or built up dust and debris, then it could be a hardware issue where the pavilion wifi isn't as good as the vaio's. The same thing happens to me on my hp pavilion dv2000.
In Windows/Control Panel you will see network connections. Open that folder and find the card you are trying to use. Right click on it and select enable.
ok its not a laptop prb if it on internet pls let me wt exactly the help mesg says it might say u to download the flash player ...or try using the mozilla firefox it will surly wrk as it has flash built in
