My brother bought a used LG Flatron monitor and while cleaning it (the previous owner was a smoker), he thinks he pushed a button because he got a box with "osd locked" and "osd unlocked" that flashes continuously on the screen. He does not have internet service so I am trying to find out how to get rid of the flashing box. It flashes even when he is playing games or using other programs.
Can you help?
Thanks, Nona
SOURCE: Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
SOURCE: MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
SOURCE: I have a LG flatron
Press and hold the MENU button for about 5 seconds. This should unlock the controls. On some monitors it will be the power button that you need to press for 5 seconds to unlock.
If none of this works, it may be a malfunction needing servicing.
SOURCE: omi have lg flatron 1941s
i have a problem with my lcd a small area is permanently black a scratch like lines less than 4 mm X3 mm size
