I had put in a new cartridge of black ink into my printer and have successfully put it in, because the computer had told me. Now it won't let me print anything off? What can I do to fix this?
You might have to do a MAINTENANCE on it. Start, Settings, Ptinters and Faxes, Rt click your printer, Properties and somewhere in there is Print Test Page or Clean Print Heads. Does this do anything?
You can also hold down one of the buttons on the printer while turning it on and force it to do non-stop test prints. Turn off to stop
Sometimes the ink cartridge carrier
won't automatically move to its loading position even when the printer is on
and the cover is open. Follow the steps below:
1. Unplug the printer from the power
source.
2. With the cover open, hold the
solid white strip that connects from the carrier assembly to the ink cartridge
carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridge.
4. Load the new black cartridge. Close
the cover.
5. Plug the printer back to the
power source.
i have an epsonstylus cx4800 i put black ink in it was out now the out of ink lightwont go off and it won't print
