Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
SOURCE: Samsung LE32R87B
I had this problem with my tv but i kept getting a black grid over anything red... i returned it to samsung and they replaced it
SOURCE: Screen shows several horizontal and vertical lines.
Press the menu on the TV and let me know if the menu is effected. If the Menu if effected , you can try unplugging the power cord for a minute and replugging it back. If the issue still persists , a physical diagnostic is necessary to determine the exact defective part on your device. It could be a problem of main board or even worse, the panel.
SOURCE: best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
SOURCE: samsung 40 inch LCD takes longer and longer to turn on
common problem you have a bad cap or 2 in your power board this board is the one where tour ac cord plug into these can like caps will be puffed up on top the values are written on the sides on the device replace them and your good to go
SOURCE: I have a Samsung Model HP-R4252 Plasma t.v., Type
please come my house and i can fix it because i am repairman for £10 only on MK11 1NY,Galley Hill,Buckinghamshire,Stotfold Court. Thank You,Tom!
Samsung is known for producing
high-quality LCD televisions with excellent imaging and sound.
Unfortunately, LCD televisions, like all electronics, are subject to
problems on occasion. Common Samsung LCD problems include a television
with sound but no picture, sometimes due to a faulty power supply.
Although these problems can be difficult to fix by yourself, it is sometimes possible to extend your television's warranty by contacting Samsung.
Picture quality problems (such as lines, fuzzy image, or wrong colors)
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
