When the throttle lever is pushed down to "choke' postion the lever at the end of the cable doesn't lift the choke lever to close the choke. The choke lever can only be lifted (by hand) when I twist the black plastic choke knob on top of the carbie. If I do this and insert a spacer to keep the choke lever up - the engine will start. Can anyone assist please?
SOURCE: Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
SOURCE: A lawn mower without a choke!!!! Won't
try google search on b&s web site with the number off the side of the head or shield. it might not have a choke, just a primer.
SOURCE: I have a Craftsman Push Rear Bag Lawn Mower w/
Your mower should definitely have an air filter whether it is paper or foam, and you should drain the oil from the bottom, not turning it over. turning it over can get oil in places where it shouldn't be and make it smoke or not run at all. It may need carburetor cleaning and spark plug cleaning or replacement, or the flywheel key may be sheared if it runs rough
SOURCE: Qualcast petrol 35s mower will only operate with
The chole is only ment to be used to prime the engine on cold start up, the engine is supposed to be run with the choke in the normally open position.
SOURCE: engine starts but won't continue
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
