incline motor is bad or needs calibrated, try this 1. remove safety key 2. press and hold the speed+ and stop keys at the same time 3. Put the safety key in/on and release the keys 4. press stop once 5. hit the incline + arrow and let the incline go the whole way up and down 6. remove safety key and try
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
If some buttons work, you more than likely have a key pad problem. Unfortunately Icon doesnt sell kep pad seperately. As a last effort, try heating up those buttons wit a blow dryer. This will work temp. sometimes.
