Can I load accounting program Myob 12 onto Samsung Tablet 10.1. Regards, Susie
SOURCE: samsung galaxy tablet is not
Make sure you are using the AC adapter as the Tab cannot charge solely from a USB cable connected to a computer or similar. If it is still not charging, your device's battery or connector has probably failed and will need to be replaced.
Hope this helps,
Alistair
SOURCE: i cannot connect my samsung
If connecting the Tab to the computer with the cable and then correctly mounting the SD Card through Android (tap notification, follow steps) does not work, try a third-party app like On Air to connect over-the-air.
Hope this helps,
Alistair
SOURCE: Samsung tablet isn't connecting to
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
SOURCE: Hi, i m not able to find the motion sensor
its in notification panel by the name orientation lock.
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
