The treadmill stopped and the upper board was on. I shut it off and tried to restart it and it appears to be dead. No lights on control board or upper board. Voltage is good to contacts checked across lower and upper control boards but lights on control boards are out. Is it most likely the lower control board?
Please see the video and fix it. LUBE the deck belt+rollers bearing front+back +test the drive belt motor, and replace it if necessary.
God bless you
Testimonial: "Thanks Ernesto, but I don't have any power so I don't think the deck repair will do anything. I don't want to pluck and chuck parts because It will end up costing more than a new treadmill and I could still not get it fixed. I need to know if the lower control board should have lights when plugged into power. Thank you though."
SOURCE: treadmill powers up begins to turn belt then shuts down
Have you tried to calibrate the speed. If not you might want to try it and see if it will help you with your issue.
SOURCE: hi i have a code E7 that show on my upper board in
Pull the connector off the incline motor off then connect (usually red and black thick leads) your multi - meter then select ohm X1 you should get a reading about 1.7 ohms. then check if the motor see if it is stuck. Then wrap a peice of cloth around the incline screw and with a pair of vise grip gently apply enough pressure to see if you can unstick that screw, reset your power and if the error code clears up, if not the VR control in the motor can be defective and you must rplace the motor.
If the reading show open I would suspect the motor is bad then again replace of the motor.
SOURCE: my treadmill motor starts exactly
that a qualified technician check the motor controller board the mosfet (IRF250N.) or diodes
SOURCE: Fuel FT94 Treadmill troubleshooting
It stops and when I unplug it it starts again this happens 4 or 5 times what is wrong?
[email protected]
SOURCE: I have a Lifefitness Treadmill model TR 9100,
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
