JVC GR-AX230 Camcorder Logo
Posted on Aug 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problems with film playback
When I try playing back what has been recorded on my camcorder there is jerking that make it impossible to watch the film, what can I do to correct the problem, it was not always this way did I do something wrong? please give me a solution to my problem.
Anonymous
Level 2:
  • Expert 169 Answers
  • Posted on Aug 26, 2007
Anonymous
Expert
Level 2:
Answers
169
Questions
0
Helped
85528
Points
213
Try to clean the video head using a blank new tape.....just forward or rewind it until the head been clean cause using a head cleaner is damaging the head,the cleaner is so rough that why i cannot recommend of using that...if it still the problem is like rainy picture...the problem is the head it need to be replace but if the cost is to high you think you better buy a new camera....
1helpful
Fast tape playback for samsung vp-l770 can't watch at normal speed on camcorder?
Tapes recorded on one camcorder very rarely play back satisfactorily on another machine - you will have to use your old camcorder to view them, or else get them transferred to DVD
7helpful
3answers
How Do I Bypass Cinavia On My PS3 Console?
Put film on pause, exit, watch another film for 20 minutes. Return, watch film until message comes up again, pause, exit go back to other film for another 20 minutes. Etc. Eventually you will see the whole film after 4-5 shifts. Otherwise, shun Sony.
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Malfunctioning One-Touch Navigation & Joystick Control
You can try first a reset from menu, then , if firmware is available you can reinstall firmware.
Can't playback
my sony camcorder says that is recording. but when i go to play/edit it only shows a blue screen.
1helpful
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Playback
Unit has tape path alignment problems. Have it serviced
2answers
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
WILL NOT PLAY BACK NOR ZOOM IN OR OUT
WOW! You've realy got some problems. With this combination of failures I would suggest that you may have gotten envloved in some environmental conditions which have caused differing unrelated symptoms all connected to exposure to moisture. The focus data is communicated through a flexible printed cable to the lens and may have the connector eroded by moisture. Ordinarily a cleaning tape should restore playback if it indeed was able to properly record in the first place (same set of heads in use for both record and playback). If the play and rewind buttons do not function you may have another cable problem. More info could be useful. Good luck, magic seadog
Can not playback past end of first file on my Panasonic PV-GS2
I'm not sure if this will work for you but, sometimes I try to play back some of my tapes and a blue or grey screen comes up instead, although this sounds odd, if I record something(for even one second) it will let me see my film. I know this can cause problems because you may end up taping over film but if it's the only way to see your film it's worth a try!
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
