Kenmore front load washer wont drain gives F2 error
Kenmore front loader washer will not drain the water if the clothes are in the washer. The F2 error appears. I cancel the cycle and have tried to drain only with out the spinning and still the water wont drain completely. Only until I take all the clothes out of the washing machine then use the drain button but turn of spinning cycle does it drain fully. I then put the clothes back in and it goes through the spinning cycle. This used to happen every once and a while but now its every cycle.
very confused.
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump. http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
The F2 error code indicates that the washer spent too long in the drain cycle,that typically is due to the drain pump filter being clogged. It's fairly easy to clean that filter by removing the lower panel and unscrewing the filter on the lower right side .Be prepared for some (perhaps a lot) of water to come out when that filter is unscrewed so have some towels or a couple plastic tubs to catch the water that comes out DO NOT completly remove that screen until all the water has come out or be prepared to get very wet by pulling it out without first catching the water
Hope this helps and if it does please give me 4 thumbs up
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged. 2. Check the electrical connections to the pump and ensure the pump is running. 3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
The filter on your pump is probably clogged with lint and
stuff. You have to remove the bottom front panel, 3 torx screws
underneath. The
panel will drop and come off. Drain off the excess water from the hose
you
see.The white filter cover is right in front.
Get yourself a bunch of towels or a good big plastic bag to collect
water.
Unscrew the filter cover and twist the filter out. Clean out all the
stuff and
put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits
of soap and other such things can be
stuck around the inside tub of your washer. Try this product, it works
great on
all front loaders. Use hot water with the Affresh pellet with no clothes
and
run the machine through a cycle.Also
helps with any stagnant water smells. Have you cleaned out your pump
lately.Put the pellet inside the
machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
goes through all cycles drains wont spin
