Dynex 37 inch flat panel tv.
You can buy almost any wall mount for it, just be sure of 2 or 3 things... 1st the location, you have to screw some rather large bolts into the wooden studs in the wall so check where it will be located... 2nd weight and size... You want a mount that will be able to hold up the weigh of the TV, usually the size will be between 32" to 40" (various mount sizes) Just make sure the size 37" is between the size lengths... and 3rd that it has a "tilt" adjustment... due to the placement of the TV you might get either reflection off of a light source or you may need to change the angle so that you can see it better on the wall... Hope this helps out and if in doubt be sure to ask someone at the store you buy your equipment (TV, Audio, Games, etc)...
