It was a ''gift'' from a friend who moved, It shuts down after 10-15 minutes or so, after getting hot After it cools, it turns back on. I have no warranty.
I've taken the back off, on the panel on the right, there is a live current somehow going through the bottom right hand screw (i was zapped!). Please give me any ideas you may have... you don't have the type of TV I have in your listings so it won't let me continue until I've selected something you have. I'm assuming 75 isn't far from 80, so...
The model number on my TV is TH-42PX80U.
SOURCE: THERE is a problem with
We should try a hard restart first, unplug the tv for a couple of hours then try again. Let me know how it goes and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
SOURCE: my panasonic viera plasma TH-42PX80U
Hi:
You will need to count the number of red led blinks on the power indicator, if it is at least 10 then replace the power supply it is faulty, In my years of servicing panasonic Plasma, power supply failure is about the most common failue in this class of television from this manufacture.
SOURCE: Viera TH-42PX80U Plasma TV: how to watch movies off the sd card...
How to watch videos on your Panasonic TV with a SD card
Samples videos on your Panasonic TV with a SD card
download archive
http://www.filefactory.com/file/cac5623/n/PRIVATE.rar
, unrar
and put everything in the root of the sd card
Voila Enjoy
file videos on your Panasonic TV with a SD card
Sting. Live In Berlin
http://www.getzilla.net/files/589014/private.part01.rar.html
http://www.getzilla.net/files/589016/private.part02.rar.html
http://www.getzilla.net/files/589018/private.part03.rar.html
http://www.getzilla.net/files/589021/private.part04.rar.html
http://www.getzilla.net/files/589022/private.part05.rar.html
http://www.getzilla.net/files/589028/private.part06.rar.html
http://www.getzilla.net/files/589030/private.part07.rar.html
http://www.getzilla.net/files/589037/private.part08.rar.html
http://www.getzilla.net/files/589039/private.part09.rar.html
http://www.getzilla.net/files/589041/private.part10.rar.html
http://www.getzilla.net/files/589042/private.part11.rar.html
http://www.getzilla.net/files/589044/private.part12.rar.html
http://www.getzilla.net/files/589047/private.part13.rar.html
http://www.getzilla.net/files/589050/private.part14.rar.html
http://www.getzilla.net/files/589055/private.part15.rar.html
http://www.getzilla.net/files/589057/private.part16.rar.html
http://www.getzilla.net/files/589059/private.part17.rar.html
http://www.getzilla.net/files/589060/private.part18.rar.html
http://www.getzilla.net/files/589062/private.part19.rar.html
http://www.getzilla.net/files/589064/private.part20.rar.html
http://www.getzilla.net/files/589065/private.part21.rar.html
