I wish to get capitol firs letters of every word ,i tried F3 key plus shift, it did not perform my request, is there anyone who may help me, Here Is A Example Of First Letter In Every Word A Capitol Thank You Charley
Try following :-
SOURCE: my keyboard is not working
ok, if u have installed any RAM or BIOS battery now is the time to tell me, or if what i just said made no sense then ur keyboard either has something spilt on it or its ribbon connection to the motherboard or daughterboard (depending in the laptop) is loose. about $25 down at a IT repair shop will fix that. if u want further explanation reply here,
lamby.
SOURCE: water spill on laptop dell c640
I'm sorry to say this, but the water has killed your keyboard, and you will need to replace it. There's no way of fixing it, other than replacement.
SOURCE: The Number key in my laptop overlap over the letter key.
try pressing the FN key at the same time as the number key.
The FN is a modifier key and when pushed the same time as another key, it changes what the button does usually. Many of these alternate functions can be found on the F buttons along the top of the keyboard.
SOURCE: IBM ThinkPad laptop number/letter keys stuck
Try holidng the "Fn" key and the "NmLk" keys together and see if that helps.
Jeff
SOURCE: the letter L key is not working
You have a faulty keyboard. Need to change the whole keyboard since you cannot change just only one letter key.
Note: If machine is under warranty no need to pay for the repairs.
F1
F2
F3
F4
F5
F1
Almost always used as the help key,
almost every program will open the help screen when this key is pressed.
Windows Key + F1 would open the Microsoft
Windows help and support center.
Open the Task Pane.
F2
In Windows commonly used to rename a
highlighted icon or file.
Alt + Ctrl + F2 opens a new document
in Microsoft Word.
Ctrl + F2 displays the print preview
window in Microsoft Word.
F3
Often opens a search feature for many
programs including Microsoft Windows.
Shift + F3 will change the text in
Microsoft Word from upper to lower case or a capital letter at the beginning of
every word.
F4
Open find window.
Repeat the last action performed (Word
2000+)
Alt + F4 will close the program
currently active in Microsoft Windows.
Ctrl + F4 will close the open window
within the current active window in Microsoft Windows.
F5
In all modern Internet browsers
pressing F5 will refresh or reload the page or document window.
Open the find, replace, and go to
Starts a slideshow in PowerPoint.
