I took the front off and left the door off pushed the safty button in and heated up fine screwed door back on did not heat up then took safty switch out and left it in my had started dryer up with door open it heated up shut door and flame went out
SOURCE: I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
SOURCE: Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
SOURCE: Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
I wote a short essay on this problem. To keep from being redundant I have it HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
