It's flashing f13 and the service light is on any help would be great :)))
SOURCE: whirlpool awo/d 4305
If you're talking about the drain pump clean out trap, the following link explains how to check it and clean it:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
This is the only "filter" on this washing machine. If you need service information, the manufacturer normally places technical information inside the appliance behind the bottom panel under the door. Look inside and there should be a tech sheet taped to the inside of the cabinet walls, or inside the bottom panel. I hope this helps you. Let me know if you require addtional assistance.
SOURCE: my washing a whirlpool awo 10761 front loader,when
If you can still open the door when it's supposed to be locked it probably means that the interlock on the door catch is faulty.Easier to fix than if the door is locked shut!!...Not a big job but should be done by a qualified tech. See if you can find an independent, self employed tech...Generally cheaper and better than 'Brand Name' servicemen..Good luck..........Nomess
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
SOURCE: My Whirlpool AWOE 8748 washing
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
