Bosch Nexxt 300 Series WFMC2201UC Logo
Posted on Mar 28, 2009
My brand new Bosch is not draining and is showing E:13 error code
My brand new bosch Nexxt 300 series washing machine is showing an error code that says E:13. What does this mean? Is it an easy fix?
  • Anonymous Apr 04, 2009
    exactly the same. door is locked and the 800# is M-F. It's Saturday.
  • Anonymous Mar 15, 2014
    bosch vision 300 What is error code L27?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
4341
Points
19
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
When door locks ..the drain pump runs. As water enters it is drained instantly. No water in drum,drain passage clear. Unplugged the pressure sensor..still DOES IT Bosch Nexxt 300 WFMC2201UC/13
Possible that the drain pump is running due to a small leak is present at the base of the machine, providing this has a metal cover on it ,it gets water in here which activates afloat switch switching on the pump hence draining the machine to avoid possible flooding, if the pump does not appear to be running then the drain hose is too low resulting in syphon effect,in which case raise it...Good luck
Is there a way to reset the computer my bosch 300 nexxt series washer?
turn off THE POWER by c. breaker, wait by 45 seconds, and turn ON again and try it.
God bless you
2helpful
Is there a reset button on a bosch 300 series washing machine
turn off the power to the unit for 45 min, that resets it
8helpful
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
1helpful
2answers
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
Im getting an error e 13 message and the door will not unlock
error code = bad pump? or just a clogged screen /kinked drain hose?
E:13Er:13 test #P:15Drain pump time exceeded,Faulty drain pump, wire harness, hose
Hello! My Bosch Nexxt series 300 washing machine is showing a E: 13 error and won't open. I have tried unplugging it but that doesn't seem to help.
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
26helpful
Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
