My Tricity Bendix AW1400W washing machine fills with water and drains, but does not spin. Checked drum belt, okay. Tried clearing all pipes. Selected spin cycle and manually moved dial. Start/Pause and door lights flash and spin button is lit. Then end button lights and machine makes beeping noise.
Brushes okay. Opened timer and control assembly. Inspected electronic panel and found the Triac(the device clipped to metal heat sink with three connections to panel) was poorly inserted and needed inserting correctly and re-soldering. Phew! ?:-)
Found fan belt on the inside floor of the washing machine. Can you tell me how to put it back please !
Thanks stuart888. 5 years later same problem so opened timer housing and found a bad solder connection to one of the relays. Re-soldered and back in action.
Bendix Biw125 wont fill set it to any programme and start/pause and door light blink. Hit start and Filter spins but machine doesnt fill. Cleaned filter checked water connection and cleaned drainage pipe still same issue.
