My washer is beeping and making a clicking noise.
See this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the
washer was plugged into an running the appliance a hair dryer works good
for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to
access the wiring to the control. Find the wire feeding the control
from the main power cord. If you cannot visually see this refer to the
tech sheet or service manual. Connect voltmeter to the 2 wires feeding
the control if it is recieving power and it does not respond replace the control board
