See this steps and fix it. God bless you Check Power
Check the outlet by plugging an appliance into the same outlet the
washer was plugged into an running the appliance a hair dryer works good
for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to
access the wiring to the control. Find the wire feeding the control
from the main power cord. If you cannot visually see this refer to the
tech sheet or service manual. Connect voltmeter to the 2 wires feeding
the control if it is recieving power and it does not respond replace the control
You have a clogged drain line their should be a plastic filter inside the washer located on the main drain line remove the plug clean filter and snake hose if ness. Make sure you have a container to catch water if not drained all the way
frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
It helps trying to actually weigh your dirty linen. Try to wash within what is mentioned in your manual. Also see that the door is closed firmly. Would be useful if you'd post back results.....
we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
