Question about Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair
How do I charge My Pronto M51 motorized wheelchair?
Someone gave me a pronto m51 sure step motorized wheelchair but no manual was given..my question is: Is it safe to charge the battery overnight? Is there any danger of overcharging? If anyone knows for sure please let me know..thanks Margie
  • Anonymous Mar 17, 2014
    pronto m61 sure step
  • Anonymous Apr 01, 2014
    i HAVE A pRONto A 91 wheel chair. do they still make them
  • 40 Answers
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Posted on Mar 29, 2009
I also have a Pronto M51 and use it daily. I have found though by leaving the charger plugged in over a weekend, it reduces the battery range and does not come back to normal until I use it for a week and charge it nightly. You can overcharge the batteries because the charger does not shut off entirely. I have monitored this with my meter.
Posted on May 13, 2009
  • spotdye Aug 29, 2010
    My invacare pronto sure step m 51 wheelchair where it shows the charge of the battery it keeps running across the screen and you can't use the thing. It won't move. It does this every time after taking it off the charge.
    New Friend:
How do i charge my pronto m51. it has a power cord that u plug into the back. do i leave the power turned off on the chair while i charge it? and how long do i charge it for?
Posted on May 29, 2010
  • JimDrover Dec 15, 2010
    ACTUALLY THE PRONTO M51 CAN BE CHARGED 2 WAYS.
    THE FIRST WAY IS WITH THE SUPPLIED CORD THAT PLUGS INTO THE ON BOARD CHARGING UNIT LOCATED ON THE REAR SECTION BELOW THE BACK OF THE SEAT AND THEN DIRECTLY INTO THE WALL. (NOTE THIS METHOD DOES NOT NEED A POWER CONVERTER BOX IN BETWEEN THE WALL AND THE ON BOARD CHARGER PORT.
    THE SECOND WAY IS BY PURCHASING THE OPTIONAL INDEPENDENT CHARGING UNIT THAT PLUGS INTO THE FRONT OF THE JOYSTICK IN THE ROUND FEMALE RECEPTACLE.
  • antonio ilagan
    antonio ilagan Jun 02, 2017
    hi i am antonio from the phils. does pronto's built in charger run on 220 volts outlet?
6ya staff
SOURCE:
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎
    Adfixya.com/Pronto+M51+Troubleshooting‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ...
www.manualslib.com > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
Dec 25, 2015 | Health & Beauty
How many batteries does a pronto electric wheelchair use
The Pronto M51 takes two batteries. It takes what is called a U1 size battery.
May 26, 2014 | Invacare Pronto M51 Power Wheelchair
Reset button on pronto m51
There is no reset button on a M51 chair. Invacare puts fuses in the battery harnesses. The manual may say there is a reset but trust me there is not.
May 20, 2014 | Invacare Pronto M51 Power Wheelchair
Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Apr 21, 2013 | Invacare Pronto M51 Power Wheelchair
Need operating manual
goto invacare.com when the home page comes up on the left side of the page you will see product catalog under that select Wheelchairs and top end. Next screen select Power Wheelchairs. Next screen select Pronto Series. Next screen select non-powered seating. Next screen select Pronto M51 with Sure Step. That is the last screen on the left side you will see owners manual select that and you can print it out with Adobe. Good Luck Hope this helps
Oct 11, 2010 | Invacare Pronto M51 Power Wheelchair
Someone gave me a pronto m51 sure step motorized wheelchair but no manual was given..my question is: Is it safe to charge the battery overnight? Is there any danger of overcharging? If anyone knows for...
Jo, nope you are safe. Most of the chargers are designed to cut off and go into trickle charge once they sense that the batteries are fully charged. The problem with overcharging comes after 18 hours or so. You should never leave the charger plugged into the chair for more than 24 hours. On the M51 the charger is built into the chair so just plug it in when you go to bed and unplug it when you get up and you'll be ok. You can check for full charge by looking at the charger there should be a red light and a green light when fully charged. Hope this helps
Sep 08, 2010 | Invacare Supply Group Invacare Pronto M51...
Manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
scooterworks@xnet.co.nz
May 18, 2010 | Invacare Supply Group Invacare Pronto M51...
Circuit Breaker on Pronto m51
http://www.invacare.com/doc_files/1125085.pdf
Here's the manual. Locate battery cables follow them to the motor and Joystick. you'll see the reset button
Aug 08, 2009 | Invacare Pronto M51 Power Wheelchair
Open Questions:
See all Invacare Supply Group Invacare Pronto M51 Power Questions
Invacare Supply Group Invacare Pronto M51 Power Wheelchair - Blue - Power wheelchair Logo
3,308 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
