Some module is worn n probly gittnhot. Git car scand free at autopart. Ucan disconnect batt afew or unplug car computer n clean pins. On older cars half the time it clears ussue
Wiring schematics are your best friend at this point. Locate the ground circuit for the stereo (first on the schematic, then physically on the vehicle). For a component to receive "partial power" but not function as intended, the ground circuit is the best place to look. A corroded ground or a splice or crack in the ground wire should be the cause of your problem.
It sounds as though your stereo may be improperly wired, or perhaps there is a blown fuse or exposed wire causing a short. I would suggest checking the wiring diagram for your vehicle/stereo, or taking it to car audio store/ whomever installed the unit, and having a technician examine it. I hope this helps =)
hi this sounds like you have connected the permanent live wire to an auxiliary wire, ie, what ever the power source you have connected it to, only works until the vehicle has started, then the power is stopped, sorta like.. say, the starter motor, it only uses the power when it is needed then when it is running it shuts the power off, just like the lights on the dash ect ect, your best bet would be to find a permanent live from the battery supply...hope this helps
I have the same deck. replace the flex ribbon to sub panel. It's a problem with this deck. I've replaced the rear panel ribbon numerous times as well as the front panel ribbon.
