Hello, Julz -
Instead of looking for more recipes for your Crofton bread maker, or any other bread maker, I looked for information as to why the bread made with a bread maker would collapse on top.
The answers I found on this online baking formum:
http://www.thefreshloaf.com/node/9725/bread-machine-loaf-collapse-when-baking-starts
may prove instructive.
To summarize, some of the causes and remedies for bread maker bread collapsing on top:
- You may reside at a high altitude and have not adjusted the recipe so that it does not over-proof [over-rise]. Cut down on the yeast, sugar, and salt.
- Even if you are not at a high altitude, try a recipe with reduced amounts of yeast, sugar, and salt (try reducing the amounts by 1/4 to 1/3)
- Use the dough mix cycle; Then turn the machine off and let the dough rise a little less than the recipe calls for; When you see the dough has risen turn the machine on to bake.
- If your bread maker allows,.reduce the amount of time between rise and bake
If you want additional bread maker recipes, you will find more here:
http://allrecipes.com/recipes/338/bread/bread-machine/
I did find a PDF document (Adobe Reader software - free) for a model of a Crofton Breadmaker, model MD 8505. In case you do not have a manual for your machine. The manual I found has information on how to make adjustments for altitude (page 22) and other adjustments to make (pages 23 - 24), including what may cause the loaf to fall while baking. This is the link to the manual:
Best wishes.
