I want to send my pictures to my computer from my phone. I have a bluetooth device goes in my computer model #gbu221. how do i load pictures to the computer?
<p>Sending images is easier than ever to do with Bluetooth. The
Bluetooth function is a wave viable communication link allows electronic
devices to share and transfer media such as photos, music and even videos
without any physical connection. In most cases, users choose their cell phone
to send pictures to the computer as a way to upload. However, most of the work
is done by phone. By setting up user, you can use the Bluetooth function on
their mobile phone or computer to easily send photos for free. <br />
<p>1. Press the phone "Menu" or "OK" button
and navigate to the Pictures folder on the phone. <br />
<p><br />
<p>2. Search photos stored on the phone and find the photo you
want to send images from the phone directory. <br />
<p><br />
<p>3. Press the right phone, the pictures "menu"
Options. "Select the action" Send Options "pop-up menu. <br />
<p><br />
<p>4. Select the "Bluetooth" option to send the
submenu. You will be prompted to power the phone's Bluetooth component. <br />
<p><br />
<p>5. Press the phone "Menu" or "OK" to
"Yes" option and confirm that the Bluetooth component. Bluetooth
phone menu opens automatically. <br />
<p><br />
<p>6. Select Search to search for compatible Bluetooth-enabled
electronic devices by selecting "Browse Device" option in the
Bluetooth menu. (The phone must be connected to the receiving device for photos
sent successfully.) Component Bluetooth phone will start searching for devices
within easy reach. <br />
<p><br />
<p>7. Select receiving electronic device is the name of the
list of Bluetooth devices from your phone lookup. A request to accept photos
sent will be sent to the receiver. If the request is accepted, the image is
automatically sent from your phone to the receiver. <br />
You can get picture transferred to Your computer using the bluetooth of Your phone or through the USB connection or through the memory card of Your device.
To use the bluetooth of Your phone please follow the steps below:
Ensure the computer has a bluetooth device or You connect a bluetooth dongle to the computer,
Turn on the bluetooth of Your phone,
Select the picture You want to send to Your computer one by one,
Then You select receive a file from the bluetooth option from Your computer,
It will search for the phones bluetooth device, then You accept it from the computer, do not use the pass key mode on the bluetooth settings,
It will load and send the file to the phone.
To send picture through the memory card, please follow the steps below:
Turn off the phone,
Remove the memory card of the phone,
Get a memory card reader and insert Your memory card into it,
Then You connect the memory card reader to the computer,
It will read like a USB drive and install its drivers,
Open the file to view folders, or You go to the phone and open it from its position i.e Removable drive E:,
Go to the picture You want to send to Your computer and copy then to the document of the computer,
Safely remove the device by ejecting it from Your computer(to eject right click on the position and select eject),
To transfer picture to the computer using the USB cable, please follow the steps below:
Connect the USB cable to the phone,
Connect it to the computer,
The computer will install the drivers of the phone,
Then You open file to view folder,
If the phone does not connect to the computer, it might require the software disc that came with the phone, insert it into the computer and allow it install,
Once the computer recognizes the phone,
Click on open files to view folder,
Then You select the pictures You want to transfer to the computer and send them to Your computers picture folder.
To send or receive pictures or any file, you need to be sure that your phones bluetooth is turned on, without it your phone will not be able to send or receive pictures or any files. Also, you can transfer files to a computer using a USB cable, connect it to a computer and other devices that Has a USB hub. Files can also be transferred through the SD memory card, you can transfer pictures to the memory card and remove it from your device, then you turn off your phone, remove the memory card, install it into other devices that allows memory cards, then you copy pictures from the memory card to other devices.
To use your bluetooth in transferring the pictures from your phone to other bluetooth devices, then you turn on youe bluetooth by going to the phones menu, select the settings, then you go to the bluetooth and turn it on, make sure the bluetooth device of other phones and devices are turned on then you select the picture to send and select via bluetooth, it will search for the available bluetooth devices, then you select the one you are willing to send your pictures to then you either pair id the device is not familiar, ensure you use a password that is easy to remember to pair with the other device.
That way your phone will be able to send the pictures. That should solve the problem.
Hope this information assisted you!
It is because the software for your Nokia phone is not yet installed on your computer for the bluetooth connection... This happened to me as well... so you are not connecting via bluetooth just go to your Control Panel and go to Systems then Hardware and then Device Manager under Other devices, uninstall everything and go to your bluetooth devices and remove the Nokia phone that is in the box (Control Panel >> Bluetooth Devices) you should not be asked again for the drivers once you have rebooted after this...
download lg's connection software. unless your phone shows up as a mass storage device under my computer then u will need soem drivers for it anyway. also services totally vary from computer to computer and bt device to bt device. try another computer
hi! Goto setting switch ON the bluetooth! install the bluetooth devices to the computer! insert the device in the computer! pair the mobile and computer!select the pictures and send through via bluetooth! and finaly u transfer mobile picture to the computer!
Thanking you.........
Hi there. what operating system are you running? You may try using the driver from IOGEAR website. Go to www.iogear.com. In search field, please type in the model number of the unit and hit go. Double click the unit and you'll see on the left side "Drivers/Manual" Locate the model number and save the driver to Desktop. Once done, extract the file and use this driver instead. You may also, check IOGEAR's Tech Info Library by clicking solutions and selecting TIL - tech info library. Once there, type in the search field, type "Bluetooth" and look for Installation Guide. this will give you the step by step guide in installing the driver for the said device.
