Question about Bosch Nexxt 500 Plus WFMC5301UC
E17 error code
I'm getting an e17 error code on new front load bosch washer. does anybody know what this means?
  • Anonymous Apr 28, 2009
    I am getting a e17 error code on my Bosch Front dishwaster as well.
  • Anonymous Mar 02, 2017
    e 17 is an error from flow sensor it means its taking longer than four minutes to fill up you need water pressure checking.
    New Friend:
Got an E17 Error today on a Bosch 6450 Series washer (the user manual says Bosch Vision 300/500/DLX series). Here's what I did to fix the problem.
- Tilted the unit back, propped up the front with some 2x4 (lying flat; that's all the room I had).
- removed 3 screws (Torx 20 I think) under the front lip. Then slid the cover (below the washer opening) down. This revealed the pump to empty the washer, a manual door lock opening pull rod, and a drain line (?)
- Looking through some holes in the front panel I saw some water on the bottom of the washer... but I spent a lot of time with the pump cleaning it out first (some zipper pull got in there and made a lot of plastic shavings). - Ultimately I got my hand the bottom of the washer and soaked up the water that I could find. That's when I realized
- there is a micro switch mechanism at the bottom near the front. This must be the "AquaStop". The mechanism contains a bit of styrofoam that floats up on any little amount of water that collects under it and triggers the microswitch. So, I removed that unit, wiped the water up... put it all back together. No more E:17 error.
Still don't know how the water got there in the first place though.
Posted on Jan 01, 2012
  • 3 more comments
  • eMCee2 Nov 12, 2013
    Just tto add an update: the water I had collecting in the bottom of the washer (triggering the micro switch; causing the E17 error) was due to faulty water flow valve. The first one to go was the cold, but I have now replaced both the cold and hot water flow values. Not impressed...
  • Kelly Pyles
    Kelly Pyles Jan 06, 2014
    Thank you soooo much this was my problem!
  • POB123
    POB123 Jan 12, 2014
    Thanks a lot. That saved my day. Happened when cleaning the filter. Very little water that created the problem.
  • Chris
    Chris Nov 23, 2014
    Thank you so much for your detailed info. I really appreciate you!
  • eMCee2 Nov 26, 2014
    Just a followup to my original answer: the root of problem was a leaky cold water valve. A year after replacing the cold valve, the hot valve went bad too. Since then the door lock solenoid latch has gone... all in less than 4 years, running on avg. 3-4 loads a week. Meanwhile - we bought a used Bosch Axxis washer/dryer (for a rental suite) and I'm sure it has many X the "mileage" on it as I had to replace the motor brushes, but other than that not a problem. Makes we wonder how a company can produce great/lousy products at the same time.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 35 Answers
Hi shawn833,
F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter. Also check water pressure is not too low If all these test ok you need to run a load with no clothes with 1 cup of white vinegar this will solve your issue.
Regards
R.K.
Posted on Oct 21, 2009
    New Friend:
I had the same problem after cleaning out the filter. Some water ran into the bottom of the machine and caused the micro switch to trigger... the switch is located in a white round case, which has some styrofoam attached to it which works as a floater switch. cleaned all the water out and voila... machine runs great again!
Posted on Feb 19, 2013
    New Friend:
What happens if there's washing in there and it won't let me open the door at all?
Posted on Feb 27, 2016
    New Friend:
    Problem Solver:
Thanks
Posted on Dec 29, 2014
6ya staff
SOURCE:
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
I have a bosch lifestyle dishwasher that keeps coming up e17...we have had plumbers around and there is no problem with pipes or water so what else can it be
You did not specify the model so I can only assume what means the alarm code E17 - probably water level too high - flow sensor.
The dishwasher has, for some reason detected an overfill and is reporting that through this error code. The flow sensor note is there as that can cause this fault code to be displayed.
Dado
Jul 10, 2015 | Bosch Dishwashers
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
I just bought my washer today and it won't finish the first cycle. It is showing "E17" and won't drain. What does "E17" mean and how can i fix my washer. Help!!
When the washer shows error code E17 you need to turn the tap fully on and check that the supply hose is not bent or jammed up, next make sure the filter is clean. Then make sure the water pressure is not too low. After you do all that, run a load with no clothes in the washer and use one cup of white vinegar and the code will dissappear
Nov 19, 2009 | Bosch Washing Machines
Bosh wasching machine wfr2830 error code 7 Anybody knows wht's the problem? thanks
I am factory authorized Bosch service and parts supplier and love the Bosch products.
Contact us at:
https://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.
Thanks, Ella
Nov 15, 2009 | Bosch Logixx WFT 2806 Front Load...
I have a front loading bosch washing machine and it is flashing the code e17
Hi harleyd81899,
Regards
R.K.
Oct 21, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Plus WFMC5301UC Logo
38,081 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
