Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
dennis e younce Posted on Jul 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What order do i install screens
There are three screens and i dont know which one to put on the inside and which outside. can anyone help?
Anonymous
Level 3:
Top Expert:
  • Toshiba Master 14,553 Answers
  • Posted on Jul 20, 2013
Anonymous
Toshiba Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715307
Points
48227
You may want to search for the service manual which should have a exploded view of the screens, the outer one is of course clear and just protective/anti glare, the two inner ones must go in the correct order and both have a side that faces front.
I bought it used i dont know how to install plates or which one to use got glass plates and screen ones
there should be two grooves inside on the outside of two metal fingers the plate goes in there
2answers
Need to know the order the plug wires hook into the coils on a 2000 Mercury Mountaineer 5.0
here is the firing order for the 5.0 as well as what goes where; firing order 1-3-7-2-6-5-4-8
4helpful
2answers
My Lg Neon's Screen is crack on the inside PLEASE HELP!
I had the same problem. Take it to a local cell phone repair shop. They can order you another LCD Screen and you will be back up and running!! note: do not keep your phone in your pocket!! Please use a phone case and purchase the LG Neon LCD protector!
LG Viewty - negative screen
Maybe the back light is set to low or the LCD screen is set to low
check the phone settings ...
2helpful
2answers
My guess is that this is a contact error between the screen and the actual phone, as it turns back to normal when you put pressure on it.. Same thing happened to me.. I sent it in for reparation though, but i'm guessing the problem is a contact error...
Hi, I have had the game thrillville off rails for ever and i have never used it because i dont know what do to. The box contains 3 dics and it says..disc 1..disc 2..and..disc 3. i have tried every disc and...
You need to install the game first. Install the discs in order starting with disc 1. Once you put it in the CD/DVD drive and close it, it should bring up the install screen. When it needs disc 2 and 3, it will prompt you to put them in. If disc 1 does not start installation, then you are most likely missing a disc that would be called "Install Disc". Hope this helps and if it doesn't, let me know.
8helpful
4answers
2001 ford escape-passenger door handle assembly has small hole for actuating rod to fit in to open the door from outside.This portion seems to have broken off (white metal-alum ect).Is there a fix for this...
I just ordered the part for the inside of the door from a local ford dealer. It was in Michigan and arrived in three days to Missouri so shipping is fairly fast. The part is around $35.00. The part number is 6L8Z-78223N03-AA. Its the inside door reinforcement bracket and it comes with a new bushing for the actuator rod. I hope this helps.
Screen does not light up
you turn on airplane mode by holding the on/off button too long when turning it on. no more that 5 seconds. tough to take the screen apart, go to a nextel store, they have the tools.
Moto RAZR screen problems
the problem is with ribbon (flex cable).Take it to a qualify technician is not an easy lob
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
