gary hricewich Posted on Jul 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FF problem on Teac Reel to Reel
Teac A-1500 reel to reel tape machine. When I hit FF and then stop the tape, tape does not brake the way it should. Tape falls off the reel and gets all tangled up. Is there some kind of brake adjustment for FF? RW and Play works perfect. Please help. Thank you. Gary
winserp
Level 3:
Master:
  • Master 363 Answers
  • Posted on Dec 24, 2016
winserp
Master
Level 3:
Master:
Answers
363
Questions
0
Helped
207445
Points
1105
If you want to know more things about RSGold can go to this website www.rsgoldfast.com
Our service is the most professional and most secure and convenient
Sam Palermo
Level 3:
  • Teac Master 1,267 Answers
  • Posted on Oct 14, 2013
Sam Palermo
Teac Master
Level 3:
Answers
1267
Questions
Helped
255884
Points
1842
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old.
I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
1 Related Answer
skywavebe
Sam Palermo
  • 1267 Answers
  • Posted on Aug 19, 2012
SOURCE: teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
[email protected] if you need my help.
I picked up a reel to reel deck to play tapes that are about 30 years old. It plays fine, but I noticed the take up reel is about 75% full, but the play reel has about 40%, so it won't fit. Thoughts?
Logically, if the full tape reel and the empty reel are identical the second must fill at the same rate the other empties and all the tape from the first will fit on the second.
What does happen, however, is at the start the second reel seems to fill much quicker than the first reel is emptying, which is understandable when for any given tape length the second reel will revolve between at least twice as fast as the first reel and probably even faster.
A tape reel that appears to be half full will have much less than half the available tape capacity filled.
1helpful
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
1helpful
Teac a-3440 will not play
Hi Gary,
1helpful
3answers
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: [email protected] He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
2helpful
2answers
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
When play is punched in either direction it want move,not even in
yes, one nice overhaul will fix..(this can be done by you if you are daring...when u open take apart you will find a metal strip like band..I had used a bandaid for brakes the gauze side) you need new brakes (just like a car it is run down) on the reels in order for it slow & stop when it suppose to...or you can search and find a good old fashion repairman..(sorry I dont know of none)...for dragging, before playing all open reels fast fwd to one end then rewind it back to the beginning now hold the blank reel with that little bit catch tape try to tighten full side tape by going slightly going the other way not trying to stretch nor pop the tape.....now press play
Teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
2helpful
2answers
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
2answers
Reel to reel tape
did a lot of surfing,and found a number in yellow pages,made some calls.and found a supplier thankssssss. vasili..
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
