Question about Dewalt 7.2-18.0 Volt One Hour Charger
Convert Dewalt Charger DE 9116
I own Dewalt battery charger DE 9116 with 220V input power, any solution to convert internally (through the PCB)into 110V input power?
    Habit-Forming:
    New Friend:
  • 74 Answers
It is not feasible to convert it internally.
Posted on Sep 28, 2014
6ya staff
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: 18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Posted on Jan 30, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: convert 2 pin dewalt charger to 3 pin how
By 3 pin do you mean the third pin being a ground. If so that charger does not have anything internal to ground to. It is a 120Volt Double insulated tool. Let me know if you are trying to do something different.
Posted on Jan 29, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Where online can I download a Dewalt 9116 owner's manual?
Go to Dewaltservicenet.com and in the middle of the page at the bottom find the looking for manual box. Type in your model number and it will take you to a page click in the owners manual and download it from there it is 5 pages long. If I have helped you would you please rate my solution accordingly and thank you.
Posted on May 17, 2009
Anonymous
  • 33 Answers
SOURCE: i need a schematic for a dewalt dwg 9116 charger
if its anything other than replacing the cord, it is not considered "repairable" and there are no schematics offered.
there was a recall on this model charger, so a dewalt service center might be able to repair or replace it free of charge.
Posted on Dec 06, 2009
schrodingers
SOURCE: Drawing
Have a look here, you need to change 4 components to convert a dewalt 110v charger to a 220v charger http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=zh-CN&tl=en&u=http%3A%2F%2Fwww.zuojiaju.com%2Fthread-13314-1-1.html&act=url
Posted on Nov 15, 2010
Will my 240v charger work on 110v
Can't say for certain, but there are specific 110V and 220V versions of DCB101.
None are labelled 90-220VAC as would be normal for universal voltage equipment.
If you operate 110V equipment on 220V then you will most likely damage it with overvoltage.
If you operate 220V equipment on 110V then you will most likely damage it in over current or have it simply not work.
It is possible that the charger is universal, just not labelled as such.
Send DeWalt an email.
Mar 29, 2015 | Dewalt 12v Max - 20v Max Li-ion Battery...
Can I use a de 9116 charger for a 18 v 1.3hbattery please
Yes, it's charger for batteries from 12V-18V, but only NiCD and NiMH. Do not use it for charging Li-ION batteries. What type of battery you have should be stated on the battery itself.
Regards, Juraj
Dec 02, 2014 | Electrical Supplies
How can I change input voltage of charger from 120 volts to 220 volts?
http://ecx.images-amazon.com/images/I/21b-Ru01zNL._AA160_.jpg
There are a number of converters that convert 220v to 120 v and visa versa. If you do a web search " 220 to 120 converter, you'll get many sites.
Jun 01, 2014 | Bosch BC630 bc660 14.4v - 18v litheon...
How I can convert 110volts to 220 voltage in Craftsman charger 145301 because in the Peru country we use 220 v. thanks.
_Some_ chargers will allow a range of input voltages. This will probably be "Input: 100-240V" or something like that written on the charger. __You need to be sure__. Others may have a switch from one voltage to the other. The trick here is to make sure the switch is in the right position. In both cases you may also need a plug pin adapter. If the charger you have has neither of those abilities then you either need to get a different charger from Craftsman, or get a voltage converter, which will give both the right plug for your wall sockets and convert from 220V (from your wall) to 110V (to the charger). Unless the charger has voltage range or a switch, you can't just use a simple plug pin adapter.
Feb 20, 2011 | Craftsman Drills
I need a schematic for a dewalt dwg 9116 charger
Dec 05, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Can I use my battery charget for my camara in Greece?
According to this link, it says that the charger is 110-220 volts. You can look on the label and it should say "110-220", and if so, you should be good with only an adaptor vs. having to use a voltage convertor.
Mar 20, 2009 | Panasonic Cameras
Convert 2 pin dewalt charger to 3 pin how
Jan 29, 2009 | Dewalt 18 Volt Compact Drill Kit
Drawing
OK, sorry, because my internet connection went down for near a month, so ...
No problem for that, just give me your e-mail address.I will e-mail you ASAP.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
I HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
Jun 20, 2008 | Dewalt 18 Volt Compact Drill Kit
No Manual?
Online Manual (PDF) For DW9116
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/630429-00,DW9116.pdf
Dewalt DW9116 Product Recall:
http://www.dewalt.com/us/articles/article.asp?ID=187
Nov 22, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
574 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
