Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
GE Profile Washer leaking underneath during spin cycle
We have a 2-year old GE Profile washer Model WPGT9350. It is leaking water underneath during the spin cycle.We checked -- the hose is not leaking the water. Would appreciate input toward a solution.
Its your outer tub it has a hole in it
Posted on May 13, 2009
Anonymous
SOURCE:
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
My GE Profile Washing Machine Keeps Stopping
Repair requires replacement of the transmission / break assembly. Unless you are really attached to this machine, it's time for a new machine. Average life of a washer is about 11 years doing 8 loads per week. Look into the front load machines, which use about 1/4 the water and spin about twice as fast, and are gentle on fabrics while cleaning very well. Please don't bother rating this, as non FixYa ratings drop my rating, and I'm sure you don't want to shoot the messenger.
Oct 14, 2008 | GE WBSE2090A Top Load Washer
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
GW Profile Washer Model WASE4220
The motor is bad. I just fixed one like this myself. The original motor has been superceded and the new one fixes the problem.
Dec 02, 2007 | Washing Machines
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
2,096 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
