Zebra Z6M Plus Thermal Label Printer Logo
Anonymous Posted on Nov 05, 2017
Zebra z6m Plus, paper out
HI! I have zebra z6m printer and I have a problem with print labels with holes. Printer is not calibrating correctly and i see "paper out" communique. Labels have a black mark and i configure sensor for "mark". Unfortunately sensor see black mark and the holes and the printer not calibrating. Please help. PS: Sorry for my english...
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Feb 02, 2008
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Anonymous
  • 5 Answers
  • Posted on Dec 05, 2008
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Anonymous
  • 32 Answers
  • Posted on Oct 27, 2009
SOURCE: Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Anonymous
  • Posted on Apr 05, 2010
SOURCE: print spooler resends data if long delay between labels zebra
We are considering different print drivers. Zebra's tech support is horrible and staffed with lazy, blundering idiots.
Anonymous
  • 3 Answers
  • Posted on Dec 23, 2010
SOURCE: How can we change from black bar sensor printing
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Printing blank label
You need to give more info.
Are you using labelling software?
2answers
Zebra 105se printer is printing out of the label on the wright side
re donload software for it maby firmware update cheak settings in software ok
1helpful
Z6m won't stop feeding
I would venture a guess that the sensor that detects the labels isn't working well - it's supposed to see the difference between label and backing paper and stop at the correct position.
Zebra Z6M Plus no startup
here you go http://www.zebra.com/us/en/support-downloads/industrial/z6m-plus.html
2helpful
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
1helpful
Z4m zebra printer problem
Might foul the ribbon sensor, clean the sensor and try to print again.
3helpful
3answers
Printing error condition
First clean the sensor tag and sensor head open and tape. Then perform a calibration label pressing the PAUSE and FEED buttons and turn on the printer, release the keys until it starts to move the label. Wait until you are finished and ready to print.
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Zebra Z4M Plus
this is a color printer or not
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
