I cant get the cd thingy (sorry)........ to stop opening and closing. when i put in a dvd to watch it, it stays shut and when i put an audio cd in sometimes it will play if it wants to. It sounds like its trying to read a disc each time it closes even when there is nothing in there.. Im kinda computer retarded, so i dont know if its something that i am doing.
It sounds as if there is either still some obstruction within the CD tray mechanism or path, or else the CD drive itself has failed and should be replaced.
I would recommend replacing the CD drive, especially if it has already caused one CD to break into fragments.
Replacing a CD drive should be reasonably easy if you have a tower computer and are happy to open the case.
Depending on the design, there are normally only 2 screws on each side of an optical drive and 2 cables on the rear to disconnect (3 cables if you have a direct sound connection from the drive to the motherboard).
Some case may have a quick release method for removing the optical drive. You should consider replacing the CD drive with a combination CD R/W DVD drive unless you already have a second DVD drive installed.
The issue is due to the driver corruption. You need not worry, there is a simple solution for this.
Go to device manage --> right click on your CD/DVD drive and then click uninstall and then restart your computer. Do not keep any CDs while you do this. Just try this out.
My Gateway model #AR-230 tray would not open after several years of use. Removed the black sheet metal cover from the player to access the tray mounting screws in the black plastic tray frame. By tightening or loosening the little screws on both sides of the front of the tray mechanism, I got the tray to slide out (open) reliably again. The problem is the very close tolerance of the internal tray mechanism with the front case opening causes a mechanical hangup or interference. chemicalladdie
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
If the trouble isn't being caused by some screwy virus or software problem, the best solution is to replace the drive. New drives are quite inexpensive and widely available in retail stores (at higher prices) and online.
Restart the computer, and when computer is starting up keep pressing many times the eject button until disk pops out. Do this a couple of times If this does not work you will need to remove the CD/DVD unit and stick a paperclip on the CD eject hole, in the front side of the CD/DVD drive.
turn on the dvd player with the remote . press open on the remote insert the disc dvd out of the box close tray press play to watch dvd when finished press open take out disc and close disc tray and turn off dvd player .
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
