Question about Kenmore Sewing Machines
My sewing machine needle is hitting the top of the needle plate
A family member borrowed my Kenmore 385.16120200 sewing machine and when they returned it, the needle was broken. I replaced the needle and found it was out of alignment. Now it hits the top portion of the needle plate needle slot. I checked to make sure the needle was installed correctly, but that wasn't the problem. The machine doesn't look damaged, but when you turn the machine sideways and rotate the handwheel, you can clearly see it's misaligned. The point of the needle hits the top portion of the needle plate instead of going down into the bobbin housing. Any guidance would be much appreciated, thank you!
    Brigadier General:
  • 5,158 Answers
Basically have to bend it carefully back by hand.... if you have a straight edge or even a small leveler (the kind with a bubble) you can check which direction it is bent and gently bend it back a little each time.
Posted on Mar 29, 2009
6ya staff
SOURCE:
Needle thread wont pick up bobbin thread
I have found this happens when I need to replace the needle. It might be slightly bent, or the tip broken. Needles are cheap, so when in doubt replace the needle!
May 07, 2014 | Janome 8080 Computerized Sewing Machine
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
I BORROWED a sewing machine. It is a Kenmore
the thread wrapped around the bobbin case and tangled around to mess up the tension try to readjust the tension
Dec 03, 2009 | Kenmore 12912
Kenmore sewing machine needle doesn't move.. won't go up and down.. the motor is running
Sounds like the drive from the motor to the needle head has worn or is broken. You really need an engineer for this one. Hope this helps.
May 20, 2009 | Kenmore 15516 Mechanical Sewing Machine
Can these needles be used with my sewing machine?
Don't know if this is helpful...but I have a very old Kenmore and 2 Brothers. I used the same needles with all 3 machines. No problems.
Apr 13, 2009 | Sewing Machines
Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Feb 20, 2009 | Kenmore 15516 Mechanical Sewing Machine
Color coded Kenmore needles
Hi there, The different colors only correspond with the size of the needle. Green is actually a size 18 (110) needles which is basically as big as they come! your best bet would be to go with a size 11 (75) or 12 (80) needle. For the Kenmore color coding it would blue or orange respectively. Hope this helps
Dec 10, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore sewing machine 15008100 not working
Was all well and working before you did work on the bobbin area ?
Ensure the machine is unplugged & bobbin winder is set OFF as there is a clutch preventing the needle arm to operate when bobbin winding......remove the needle.
If you take the bobbin and hook out, can you manually rotate the handwheel forwards ?
If yes, this suggests they are not inserted quite right, or the timing is out of adjustment.
Can you rotate the handwheel backwards ? On some machines the clutch allows for reverse travel freely, but only around the 15 degrees you mention forward when the top cover is off.....there may be a broken or dislodged spring unit/armature inside top near the handwheel and bobbin winder assembly that is acting as though the top cover is open (a safety feature)....generally towards the rear of machine and acting like a log thrown into a gear.
This may help straight away, or only just start to unravell the cause....
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Mar 16, 2008 | Sewing Machines
Tye of needles
you can use schmetz, i actually prefer them
Jan 20, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
432 people viewed this question
Top Kenmore Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
