Vizio VO47L 47 in. LCD TV Logo
Posted on Mar 30, 2009
Picture is now a series of moving bars, can't get proper picture
4 month old 47" Vizio LCD TV has gone bad. Vizio says I did not buy from authorized dealer therefore no warranty. Hope to get some help from retailer Monday.
Picture is a series of moving horizontal bars of color. Can't get anything else to happen with menu button or channel change. I am hoping for a simple fix, would like some help to narrow down. Thanks Bob
  • Anonymous Apr 17, 2009
    I have the same problem and I too did not purchase this TV from an authorized dealer.. I cant find any information on line about this problem..
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Mar 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
8248
Points
36
Lose cable connection for the lcd pannel
Temporary black screen on Vizio XVT553SV
Please try to turn off the closed caption function by access the TV set up manual
1helpful
47" vizio turns off by
It may have dying power supply due to bad caps or the main board is bad, it will require in-depth troubleshooting.
When the picture cuts out, see if the backlights are still on.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
I have a vizio 47" lcd tv that was affected by a
I believe the main baord is bad (main board contains the inputs circuits, tuner, sound and video processor).
http://www.shopjimmy.com/vizio-3642-0722-0150-main-unit.htm
http://www.shopjimmy.com/vizio-3647-0102-0150-main-unit.htm
You may want to look inside to see if you can see any burnt components.
Parts: http://interliquidparts.com/
The TV is less than 4 months old and problem started after first month. It powers off for anywhere 3 to 8 minutes. Vizio Logo is flashing until it powers up again. Last night it started after 45 minutes...
Take it back where u bought it exchange it for a new tv.This tv have a major issues,with the board that call the tv Tuner signal board.This is the board the take in the incomming broadcasting signal wire plug into this board to produce a picture out of the incomming broadcasting tv signal.
Vizio vo47L 47" LCD. No
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#$
3helpful
3answers
Same problem, vizio 47" LCD TV, six month old
change out the LVDS cable (the cable that go from the control board to the main board) and it should resolve your problem. If your TV is still in warranty, call 1-877-MY-VIZIO and they will set up an in home repair for free.
1helpful
Vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Picture on Vizio HD 47" LCD TV freezes
It sounds like a main board failure but it could be the power board as well, to find out your going to need to test the power supply voltages when it quits
3answers
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
