SOURCE: Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
SOURCE: torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
SOURCE: kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
SOURCE: need to replace seal on transmission on kenmore 41793802200
If you have no transmission experience DO NOT DO IT YOURSELF. lots of parts inside and one tiny little misplacement of a gear and you can ruin the entire thing. have an experience techincian come out and replace it for you.
SOURCE: my kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
I disassembled the washer from the top and under the wash basket and going through the outer tub is a bearing that appears to have a seal around it. Almost looks like an O-Ring, but attached to the bearing. I found a parts diagram on SearsPartsDirect but it does not show the shaft the motor drives, nor the bearing or seal at the bottom of the outer tank. Anyone know if this seal is probably the problem and where I can get one? Maybe it's not a replacable part. How do you remove it from the outer tub? Is it driven out from the bottom?
