Did u put coolant back in the radiator ?when you put the new pump on you want to also drain the radiator and flush the system so its clean and then put new coolant in the radiator then start the car and fill it untill it stayes at the top then you will know that all off the passageways in the motor are full of coolant
SOURCE: changed water pump now my 95 jeep grand cherokee wont start
A 50/50 mix of an ethylene glycol based anti-freeze and water is recommended at all times.
The solution not only has a lower freezing point than water, it has a higher boiling point to prevent overheating.
Year round it acts as a rust preventative.
If you have A/C, it will prevent your heater core from freezing up.
Alcohol or methanol base coolants are specifically not recommended.
But to answer your question specifically:
To start, just water will work.
If this helped, please take a second and rate my response.
Mike
SOURCE: 2000 jeep wrangler just shut off changed fuel pump
check foe fuel pump presure at fuel rail,,,if u have fuel pump presure check all fuses with a test light not buy sight,,could be deceviving ,look at and check to see if fuel pump relay is working if no fuel presure i,if u have presure in fuel rail ,replace the cranck shaft sensor
SOURCE: my 2002 jeep liberty is running hot i have changed
your clutch on cooling fan could be faulty or your radiators cores is blocked and restricted.also grilled could be blocked restricting air flow.
SOURCE: Jeep Grand Cherokee running hot. I've changed the
Check your radiator for external and internal obstructions (leaves, bugs etc on the a/c condenser or leaves between the condenser and radiator, rust or calcium deposits inside the radiator core all cause loss of heat transfer)
Also make sure that the system is full and that the electric fan and the clutch fan are operating properly. (electric fan should come on just above normal operating temp and clutch fan should not be "freewheeling" above temp either)
Note: If you need to have the radiator flushed, do it separately from the engine. especially the inline 6 and 4 engines rust up inside and if the system is flushed with the radiator connected, the debris will pack up inside it and actually can worsen the condition.
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://www.howtorepairguide.com
These will help.
Thanks.
What to Do When Car Turns Over But Won't Start?
Car starting issues?
Car Starting Problemshttp://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html--------------
Car dead and will not Start?http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
--------1995 Lexus LS400: Running Hot?http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
---------1996 Jeep Grand Cherokee: Engine will not start?http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html-------------Mitsubishi will not starthttp://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
